80q b4 2.2 20vt project
  • Grillage
    • Apr 2012
    • 156
    On the Log, the blue lines should be the teeth on the flywheel, the white line is the camshaft sensor and the pink is the spark plug firing (or being told to fire)
    your flywheel has 135 teeth so you should have 27 teeth per camshaft sensor line. Those will not all show up zoomed out like you are but you should also be firing all 5 cylinders between each cam sensor reading.
    Here's my old V8 cq's triggerlog:
    All 8 fired between each cam sensor line
    I think you have something set up wrong or something
    1994 Cabriolet - 5 speed
    1995 90
    2011 A4 Avant
    1990 CQ - V8 (sold)
    • Thuppu
      • 4115
      • Grillage
        • Apr 2012
        • 156
        Nice - looks like you got it squared away!
        1995 90
        2011 A4 Avant
        1990 CQ - V8 (sold)
        • Thuppu
          • 4115
          It seems that what shows up in the log depends of the divider. If using Divby3 then there is 27(54) spikes shown, but when using Divby27 then log shows only 5(10), Divby9 show 15(30).
          There is a couple of things that maybe was wrong.
          First I thougt it may be the hall dizzy, turned it 180 degrees. But in the end I turned it around so many times that I'm not sure which way it was to begin with.
          Second was that I maybe had the reference tooth table wrong with the divby27. I changed to divby9 and then I relised that there is the referense table. I don't know how this affect..? Now using divby9.
          Third is that the engine was cranked so much that there was propably quite much fuel in the engine that helped it to fire on. Will see tomorrow how it starts again cold.
          • Thuppu
            • 4115
            Got confirmed that the 1.8T IAT sensor is the right one. The old stock PTC sensor won't work with this ecu.
            • afterthought
              • May 2014
              • 128
              On VEMS you've got that "Flood clear mode" you can use.
              Marc pointed this out to me and it has been useful when I was trying to diagnose whether I was too rich or too lean.
              To get into flood clear mode hit 100% throttle while cranking.
              Good to see you've got it running
              • Thuppu
                • 4115
                Ok, thanks. One more vid. Not much happening but anyway...
                • afterthought
                  • May 2014
                  • 128
                  Sounds awesome and such a good looking car! Look forward to a drive-by video
                  I wish I had those wheels and all that room that you have with the front mount rad.
                  • Thuppu
                    • 4115
                    So coldstart(~20C) was just fine today so seems to get right amount of fuel to start properly. The coolant expansion tank started to leak as it had a crack and was repaired with silicone. Bought a new and fitted it today. The engine runs quite hot at idle, it stays at 98-99C, the fans keep the temp there. The fan thermostat could be little cooler version. Havn't driven with the car yet, so don't know how it holds the temp when cruising.
                    • V6quattro
                      • Sep 2008
                      • 949
                      You have the richt calibration for the sensor in the Vems?
                      • Thuppu
                        • 4115
                        Yea, I'm not sure about the right calibration, but also cluster temp gauge goes some bit over 90C.
                        • No Limit Performance
                          • Jun 2011
                          • 4
                          • Country: Bulgaria
                          #147
                          Whats the material of the manifold?
                          • Thuppu
                            • 4115
                            It's normal mild steel.
                            • Kiku
                              • Aug 2010
                              • 497
                              Well the temperature is taken from the back of the block? It's the most hottest place for coolant. I had same issues(driven ~94* degrees and when idle'd for a while ~98* degrees), even with AAN manifold adapted Vidars thick 70mm coolant radiator. 82* degree thermostad made it all good. Code: 069 121 113 S3, febi code: 18280.
                              Mesurements with Maxxecu and double checked with infrared temperature "gauge"?
                              • quattro-nick
                                • Sep 2012
                                • 1746
                                • Country: Belgium
                                #150
                                my water temp in vems is always around 98 degrees on idle
                                TWINCHARGED power,zero lag
                                AEM W/M injection
