Oil recommendations and questions here - The Definitive S2 Oil thread
This is a sticky topic.
  • V6quattro
    • Sep 2008
    • 949
    Hy Oilman,
    I like to order a new oil thermostat but i can choose 2 temperatures. A 215F/101celsius or 185F/85celsius. I use your Miller Nanodrive 10W50 oil. Which one would i use for my 700hp avant?
    Improved Racing's Flow Series Motor Sport (FSM) oil thermostat is a universal solution that can be used with any oil cooler on any vehicle or industrial application flowing up to 20 GPM (75.71 LPM). Trusted by professional race teams, OEM's, and military contractors. Accelerates fluid warmup time and maintains a minimum fluid temperature. Patented high-flow design with no valves, springs, or other obstructions in the primary oil flow. Features -10AN female O-ring boss ports. Optional adapter fittings available in various sizes. Lifetime warranty. Made in the USA.
    We specialize in high-performance oiling system products such as baffled oil pans, thermostats, oil catch cans, oil cooler adapters, and oil coolers for GM LS engines, Ford engines, and others
    • oilman
      • Jan 2006
      • 996
      Your ideally looking to keep the oil at an optimum bulk temp of 100degc, as long as the 101celcius one does not cause the oil to over cool it could be a goer.
      Guy
      Use the code S2F and get 10% Club Discount
      oilman's website for BMW engine oil and much more - register for news and offers
      email: sales@opieoils.co.uk
      phone: 01209 202944
      • gnutz2
        • Aug 2006
        • 928
        @v6quattro, do you have problems with your oil not getting up to temp?
        I've heard people say s2's have a thermostat fitted but I've never seen this confirmed.
        My oil rarely gets to 100c.
        The ONLY S2 Golf!
        http://www.s2forum.com/forum/showthread.php?t=19402
        10.42@138mph
        https://m.youtube.com/watch?v=0wnkkOfFpXg
        • V6quattro
          • Sep 2008
          • 949
          Guy
          Thanks i will order one!
          Yes i did have problems with the oil temp. Its not getting on temperature as before on the highway. I have a big mocal cooler fitted but never had problems before.
          I'm 100% sure the S2 has a oil thermostat. I took it apart to see but i looks fine. But the low oil temps are still an issue so i like to try the Improved Racing thermostat.
          • diesel des
            • 3896
            #425
            Any discount codes coming up soon? What oil do you recommend for a vw toureg gearbox and diffs. Manual 2.5tdi car. Cheers
            • oilman
              • Jan 2006
              • 996
              Hi
              There are always different offers happening, it's worth keeping an eye on the current offers section of our site. Not sure what offers are planned.
              The UK's largest independent supplier of automotive oils, fluid and parts. We've products to suit any vehicle, from full blown Race / Track weapons, to Daily Drivers looking to save money. Plus FREE expert advice & recommendations - OPIE KNOW OILS
              I would use this in the gearbox.
              Assuming it doesn't have a LSD, the diff needs a 75w-90 GL5 oil.
              The Fuchs Syn 5, Millers CRX, Redline 75w-90 GL5, Motul Gear 300 and Gulf Competition are ideal for the diff. The Fuchs Sintopoid, Castrol Syntrax Longlife, Millers TRX, Motul Motylgear, Mobil SHC and Gulf Syngear are also good choices.
              Tim
              phone: 01209 202944
              • diesel des
                • 3896
                #427
                Thanks Tim I have ordered 2 20l drums of engine oil using the forum discount. Great stuff!
                • oilman
                  • Jan 2006
                  • 996
                  Thanks for the order.
                  Tim
                  phone: 01209 202944
                  • Eastcoastrs2
                    • Sep 2013
                    • 95
                    • Country: Australia
                    #429
                    Hi Oilman,
                    I drive a 1995 audi rs2 often rather spiritedly.
                    I have been using penrite enviro+ fully synthetic oils but they have a 10 tenths racing oil that is actually slightly cheaper and i am wondering if it is as good or better?
                    Hope the numbers in these links mean more to you than me
                    For nearly 100 Years, Penrite has served the lubricant market in Australia with products such as engine oils, automatic transmission fluids, gear & differential oils, coolants, greases, heavy-duty engine, hydraulic & industrial oils, farm and construction products
                    • oilman
                      • Jan 2006
                      • 996
                      For your car, the ten tenths makes sense as it's an ester based performance oil. The Enviro+ is aimed at modern low emissions cars, so more suitable for the Audi TFSi and new diesels than your car.
                      Tim
                      phone: 01209 202944
                      • edge_devil
                        • Jun 2009
                        • 186
                        Hi Tim,
                        I notice you have the deal for "Gulf Formula GVX 5w-30 fully synthetic engine oil for VW / BMW / Mercedes-Oil and Filter Service Pack: 6L + UFI oil filter". I'm running a more or less stock S2 ABY lump, chipped but no MAP change in the ECU, powerflow airfilter, and it's all in a totally different body that is somewhat lighter and more aerodynamic . I don't generally see anything above 95 degrees for the oil temperature (but I am measuring it in the side of the block not the normal location). Do you think this is a suitable choice or should I go to 5w 40 or 50. At present I have 5w-60.
                        Ta mucho!!
                        Tim (2)
                        • oilman
                          • Jan 2006
                          • 996
                          Hi Tim
                          I would probably go for a 5w-40 as it's an older engine with larger tolerances than the newer VW engines that use oils like the GVX.
                          Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS/CFS NT, Motul Sport/300V, Red Line and Gulf Competition. The Motul 8100 X-Cess, Millers XF Longlife, Fuchs GT1 XTL/Supersyn, Gulf Formula G/ULE, Shell Helix and Mobil Super 3000 are good, cheaper alternatives.
                          Tim
                          phone: 01209 202944
                          • edge_devil
                            • Jun 2009
                            • 186
                            Done and ordered, thanks!!
                            • Fuchs TITAN SUPERSYN 5W-40 High Performance, Fully Synthetic, Engine Oil-5 Litres
                            • Opie Oils Decal Set - 6 inch-2 x Black 6" decal
                            • OIL FILTER: UFI spin-on oil filter 23.291.00-single
                            • oilman
                              • Jan 2006
                              • 996
                              Thanks for the order! Always appreciated
                              Guy
                              phone: 01209 202944
                              • JayEll
                                • Oct 2014
                                • 17
                                I'd like to have more specialist opinion for what to put in my 2.2turbo.. Currently there's 5W40 oils and I'm about to do an oil change this weekend.
                                We still have -5degC weather in here and normally oil temperature gauge shows just about 70degrees. I think I'm going to buy Castrol Magnatec 5w-40 which I have used in my previous cars but would there be any better options?
                                JayEll's garage:
                                - Audi Urs6 sedan (daily driven), 320hp/450Nm
                                - Audi Urs6 Avant scrap, 290hp/400Nm
                                - Audi A4 Avant S-line (wife edition), 220hp / 350Nm
                                - Audi Coupe 'Ugly Ducky', "what's left" hp/nm
