Buying an S2 Coupe - Am I walking into a world of pain.
  • Ian Simmonds
    • Jun 2005
    • 2858
    The good news is I doubt you’ll need a new wastegate. The bad news is figuring out what to do next. I’d be tempted to put it back as is (assuming it worked) and seek counsel from the great and the good as to either leaving it or reverse engineering it.
    93 MTMS2 Avant
    • B5NUT
      • Sep 2021
      • 1071
      Ok, so I now need the standard wastegate cap parts
      • Bowie69
        • Nov 2013
        • 2675
        Not really, just shove it back together
        Is it actually damaged/ruined?
        • Ian Simmonds
          • Jun 2005
          • 2858
          Agree, it’ll work as is, but you’ll probably need a new wastegate cap if you reverse engineer it as that hole will be massive.
          93 MTMS2 Avant
          • B5NUT
            • Sep 2021
            • 1071
            No, I just trying to put the car back to standard, so would like the original parts. It's also insured as "No modifications" so as I now know this is a mod (and a bad one at that) I would prefer the unmodified parts.
            Well I think I answered my own question about walking into a world of pain.. The answer plain & simple is yes I did...
            • Bowie69
              • Nov 2013
              • 2675
              One on ebay at little money: Audi 100 200 C3 S2 S4 C4 Turbo Actuator Wastegate KG MC AAN JY 3B | eBay
              Check part numbers of course -you only need cap.
              • Ian Simmonds
                • Jun 2005
                • 2858
                I can only apologise, you didn’t even come here this morning looking for help with a period modification/lash up.
                93 MTMS2 Avant
                • B5NUT
                  • Sep 2021
                  • 1071
                  It was a good spot, and glad it got noticed.
                  • B5NUT
                    • Sep 2021
                    • 1071
                    Could also explain why someone unplugged the n75 valve?
                    • Ian Simmonds
                      • Jun 2005
                      • 2858
                      Yep. Reading that historical thread it implies the superchip solution doesn’t use N75 whereas other modifiers do.
                      93 MTMS2 Avant
                      • B5NUT
                        • Sep 2021
                        • 1071
                        Where is the ECU on the S2 (Sorry still working my way around this car) Just wanting to see if it's been tampered with.
                        • Bowie69
                          • Nov 2013
                          • 2675
                          *IF*?
                          You live in hope, clearly!
                          • Ian Simmonds
                            • Jun 2005
                            • 2858
                            Originally posted by martinjs
                            That’s what Superchips did back in the day, they unplug the wgfv and wind the wastegate spring perch right in via that bolt.
                            And Martin’s post.
                            93 MTMS2 Avant
                            • Ian Simmonds
                              • Jun 2005
                              • 2858
                              *IF*?
                              Passenger side footwell, behind glovebox. Remove lower glovebox cardboard trim and follow the wiring loom.
                              93 MTMS2 Avant
                              • Ian Simmonds
                                • Jun 2005
                                • 2858
                                If you can picture this mounted on the back of the glovebox…
                                The ECU should slide out of the tray downwards (past the retaining spring clip).
                                93 MTMS2 Avant
