struikie - Audi 80 B4 quattro project
  • struikie
    • May 2019
    • 314
    There is no difference between B5 S4 and the B5 2.5 TDI linkage. Same body shell, same gearbox style.
    I have no first hand experience yet, but from what I have read:
    - V6 front driveshafts should be a straight fit with S2 hubs (lucky for me) otherwise gearbox flanges can be swapped from the original box (I already have a 01E 5spd)
    - gearbox is about 25mm longer, so the prop shaft needs to be shortened
    - V6 subframe should be good for the 6 spd, otherwise there can be a 40mm spacer needed on one of the gearbox mounts
    - gear linkage should be shortened by 40mm
    JW
    | project | 1993 Audi 80 VR6 turbo quattro |
    | daily | 2018 BMW G31 530d | 345bhp 770Nm |
    • struikie
      • May 2019
      • 314
      Ready to be cut.
      JW
      • 89 Coupe
        • Aug 2016
        • 125
        • Country: New Zealand
        #93
        JW
        Not to thread hijack here but if anyone is looking for more compiled info I have put together this and I am always looking for more answers to add.
        Did you mean that the B5 S4 V6 front axles will fit the 6spd 01E into S2 hubs, B4 chassis?
        I've had some 100mm A4 B5 diff flanges turned down 3mm but would like to retain 108mm if possible
        • struikie
          • May 2019
          • 314
          From what I have read (German forums) is that the B4 V6 front axles are a direct fit to the DQT box.
          Umbauprojekt 6-Gang Diesel Getriebe im S2 3B 5+E - Fahrwerk, Bremse, Lenkung und Getriebe - Audi Turbo Forum.de - DAS private Audi 5 Zylinder Turbo Forum
          Originally posted by matzerm1
          Muss meine aussage korriegren. .,
          Dqt mit den antr i ebswellen vom v6 passen p&p in den s2 naben
          Gerade getestet
          Gruß matze
          JW
          • 89 Coupe
            • Aug 2016
            • 125
            #95
            I would assume without checking that splines will be the same, our only concern might be axle length if flanges are of desired size.
            I will report what I find with B5 to B4 in my thread.
            • Henkjan
              • 1705
              great progress!
              • 89 Coupe
                • Aug 2016
                • 125
                #97
                Completely missed this before when you said B4 V6 front axles are a direct fit.
                Indeed B5 S4 front axles are no where near fitting in the B4 hubs! They are also far too long
                • struikie
                  • May 2019
                  • 314
                  Ordered the Epytec gearbox mounts to put a 01E in the 80. Asked them and they are RS2 equivalent.
                  https://epytec.de/en/engine-and-gear...-coupe-aby-abu
                  I am looking to buy a FTF (=DQT) 01E diesel gearbox in Germany. They qoute shipping at 300 euro for a 600 euro gearbox.
                  So I am going to pick it up myself. This is a 260km one way trip...
                  Need to decide to replace the front drive shaft flanges or get B4 V6 non-quattro axles.
                  JW
                  • struikie
                    • May 2019
                    • 314
                    Picked up the FTF 01E gearbox (VW Passat 3BG 4-motion V6 TDI) today at Koch Autoteile (vr6_autoteile on eBay) near Osnabruck.
                    Excellent seller.
                    JW
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      Interesting project this, I like it.
                      I have a pair of complete 1995 Coupe V6 Non quattro front drive shafts if they're of use to you.
                      1990 B3 2.0 80 quattro.
                      1992 C4 2.8 Avant quattro
                      1994 MTM RS2.
                      1998 B5 TDI quattro Sport.
                      2000 B5 TQS.
                      • struikie
                        • May 2019
                        • 314
                        Thanks!
                        The drive shafts sound very interesting, but wouldn't shipping to Holland spoil the deal a bit?
                        JW
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          No problem. I can find out for you, might not be too bad, I don't want a huge amount for them as their just taking up space.
                          1994 MTM RS2.
                          2000 B5 TQS.
                          • struikie
                            • May 2019
                            • 314
                            That would be great. I think it would be cool to have some parts on the
                            build from another forum member!
                            JW
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              Check your PM's mate.
                              1994 MTM RS2.
                              2000 B5 TQS.
                              • struikie
                                • May 2019
                                • 314
                                Got a really nice birthday present today!
                                Brand new from Autewo.
                                When the whole driveline is getting an overhaul the will be fitted.
                                Just need to gather some more parts to go and start the process.
                                JW
