Front brakes fitted.
I would like to say it was a simple job but it didn’t quite go to plan and took me most of the day.
First I fitted the carrier brackets the wrong way around. After a bit of head scratching and a text to error it was sorted. Then, powder coat was so thick it required some cleaning to get the carrier to sit right. Next problem was that the brake pipe holders needed adjustment to make them work with the HEL line.
Basically converted the closed hole to open like below as the HEL fittings are too big to pass through the holes.
I still need to sort where the HEL line meets the original hard pipe as the HEL fittings don’t sit in the brackets the same way so you can't use the spring.
Disc weighs a ton!
Disc weighs a ton!
