RS2 America
This is a sticky topic.
    #1321
    Which boot lid / lock bits specifically ?
    http://vagpart.com/audi/audi-80-avan...2740-lid-lock/
    • saltinot
      • May 2004
      • 1946
      #1322
      I need the complete wiring harness from the fuse box back. I think it has a yellow connector at the fuse box.
        #1323
        Originally posted by saltinot
        Cheers for that Paul. I couldn't have gotten this far without the help from this forum. You know that I'm bound to have something wacky happen once I put 12v to this thing. Fire extinguisher close by.
        One good tip is to simply remove all fuses and relays before you apply battery for the first time... then insert them one at a time as you check things out in sections - working up to the engine and ECU as the last item to power up... get all the lights, instruments and other ancillaries working first. That way you limit the amount of pain and complexity in a mostly modular fashion - not like the B3/B4 is quite that elegant but you get the point.
        Don't forget to add a fuse for the front washer pump - Hans und Franz forgot that in the factory.
          #1324
          Sorry I misunderstood - thought you were looking for an actuator... you mean this harness ?
          http://vagpart.com/audi/audi-80-avan...-for-tailgate/
          The whole thing is 8A9971726B looks like to me - not sure if this goes all way to the CEP or whether it mates with the rear vehicle loom somewhere around back seats.
          • saltinot
            • May 2004
            • 1946
            #1325
            I just looked it up....it's the "wiring harness for central locking and anti-theft warning system". Lots of choices under that subset. It looks like the one I need is 8A9 971 807 AL.
              Some Euro's heading your way Tom. Not much in the scheme of building an RS2 from scratch
              Hope it helps you out mate
              • rxl
                • 1913
                so what parts do you need? maby somebody of the forum has them and can supply them..
                • saltinot
                  • May 2004
                  • 1946
                  #1328
                  Got them Alex! Thank you. You guys are the best!
                  I wish I had a euro for every hit on my thread. I could have built quite a few RS2s by now.
                  Originally posted by rxl
                  so what parts do you need? maybe somebody of the forum has them and can supply them..
                  8A0121101D hose water manifold to radiator
                  893121101A hose radiator to aux radiator
                  893121101A hose bottom of coolant res to radiator
                  8A0121284H air duct right side radiator
                  8A0121283A air duct left side radiator
                  8A0121283D air duct left lower radiator
                  8A0145805C intercooler
                  ?? aux radiator
                  ?? oil cooler
                  8A1919214B Zusatzinstrumente (3 gauge cluster)
                  ?? Hydraulic accumulator
                  various heat shields under the car
                  That's just what I have written down here.
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    #1329
                    I found The rs2 oil cooler at a German dealer.
                    Will try and dig out the info if you need it?
                    Sleeper S2 Avant +450
                    A6 Avant 2.7t Stage 3
                    Audi S2 Coupe RS2'ed
                    • saltinot
                      • May 2004
                      • 1946
                      #1330
                      Yes, please Jonas.
                      I was just about to ask you for some help with a few things.
                        #1331
                        ?? aux radiator
                        ?? oil cooler
                        @Tom - I almost certainly have the water hoses in good condition - OE items taken off my ABY when upgraded to Samco some years back - they are in a box uhhhh somewhere... expect lots of folk here have those.
                        I was going to sell my ABY sized intercooler if thats any use to you in the short term - I am going up to Carsten RS2+ version - maybe you are too unless you want everything stock ?
                        I will have the radiator air ducts as well from mine - not sure if same on ABY Coupe as RS2 though - will need to check that.
                        I have two spare bombs as well (aka hydraulic accumulator) - no idea if either is perfectly healthy but happy to throw one your direction FOC if you are struggling to find a new one.
                        • Jonas_R
                          • 3781
                          • Country: Denmark
                          #1332
                          So found it at www.kuehler-rath.de
                          Part no. 86108
                          144 euro ex vat. I could also use one so perhaps we could buy two and see if we get some discount?
                          • Jonas_R
                            • 3781
                            • Country: Denmark
                            #1333
                            This auction on German eBay has the aux gauges from new 360991417957
                            • kinaputt
                              • Jan 2012
                              • 285
                              • Country: Norway
                              #1334
                              If you buy all this, it will cost you a arm and a leg!
                              trshop.audi.de have:
                              8A0121283D - Air duct
                              8A0121283A - Air duct
                              8A0121284H - Air duct
                              8A0145805C - Intercooler
                              034117021D - Oil cooler
                              895121251 - Aux radiator
                              8A0612061 - "Bomb" - F 8C-S-000 369>>
                              4A0612061D - "Bomb" F >> 8C-S-000 368
                              8A1919214B - 3 gauges
                              Ebay have:
                              893121101A - hose
                              Rexbo.eu:
                              Shields:
                              Audi tradition:
                              8A0804165
                              8A0804172
                              8A0804160A
                              8A0804169A
                              • saltinot
                                • May 2004
                                • 1946
                                #1335
                                So what's new?
