Nice idea with the grinder disc, i spent ages carefully wiping them to keep them paint free, grinder is so obvious now you say it.
RS2 America
This is a sticky topic.
I spent a few moments out in the garage yesterday evening. Decided to dig out a few brackets from my engine parts box (seen below) and bolt them up. I don't want to go too far since I still have to refinish the other side of the block.
Lol, they are just filling the void to keep out the dirt. I'm just getting started here Mr. Dave.
Aren't you going to point out that I have the wrong sensor color too? Ha!
Speaking of......I forgot to mention that I replaced the little valve that hoods oil pressure down in that hole you posted above. Easy stuff accomplished with the use of.a.small triple square. $30 from the dealer here....OUCH!Last edited by saltinot; 18 January 2012, 03:10.Comment
You mean this check valve (below) as discussed in the AAN Oil Pressure Sender, Switches and Check Valves post? ( http://forums.quattroworld.com/s4s6/msgs/96161.phtml ). That came up as issue here recently (in a different thread).Lol, they are just filling the void to keep out the dirt. I'm just getting started here Mr. Dave.
. Aren't you going to point out that I have the wrong sensor color too? Ha!
I must admit your posts are some of the best i've ever read, always have good links and where possible pics and info. Keep up the good workYou mean this check valve (below) as discussed in the AAN Oil Pressure Sender, Switches and Check Valves post? ( http://forums.quattroworld.com/s4s6/msgs/96161.phtml ). That came up as issue here recently (in a different thread).
lol
Keep up the good work tom, brilliant thread
If the one discussed is the same one in your picture, then yes that is it.You mean this check valve (below) as discussed in the AAN Oil Pressure Sender, Switches and Check Valves post? ( http://forums.quattroworld.com/s4s6/msgs/96161.phtml ). That came up as issue here recently (in a different thread).
Quattroworld, I don't frequent there. It's the S2forum for me!
Thanks. I try to help. I knew Tom wouldn't make a mistake. I just wanted him to confirm that the location of the oil pressure sender and switch were reversed for the ABY and ADU when compared to the AAN.RS2'd 93 UrS4 5 spd sedan
