Right a small update:
after fitting the tank and fumoto valve to drain to the sump, i realise that even with that being done, there is still a hell of a lot of blowby going to the airfilter and turbo, making all N75 hoses, lower wastegate chamber, mushroom filter and turbo full of oil. It is clear then that the tank alone wont work. As an alternative i must try the provent tank instead, so ill order one from efiexpress.
I cannot be bothered having 2 tanks one emptying to the other etc at least not at the moment, so for the time being the tank will vent to the atmosphere through a filter and keep everything clean hopefully.
I may end up needing 2 provent tanks, who knows! but i can say that i have had enough with all this oil residue and spill.
Brake servo is going for round 2 and probably willl be fitting one from an S2 while i send the new which turns out to be faulty back to germany for either a replacement or a refund. More to come after easter.
Finally, im not sure, but can all the oil blowby if going into the N75 valve and hoses cause boost fluctuations and such? I went out the last couple of days for some boost checking and this is what i get. Lag increasing by anything between 50-140rpm and today boost not reaching target by 0.1bar at least occasionally!.
tried 2 N75 valves(mac units) and they were doing the same. One of them, was oily in the exits,from all the blow by.
