some small update.making the heat shield look presentable!
Audi 80 Avant
Originally posted by A80Avant View Postvems does fit in the original motronic position once the metal hook is removed. I tidied a bit in there today.
expect a carbon air guide for the radiator soon as well as some new goodies from marc as spare parts.RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
Originally posted by A80Avant View Postabout 13l/100kms mixed nowdays and ill try something leaner to see if the engine can handle it. (thats around 21.7mph to the gallon)
what size of wheels are u using? and wich it is the full weigh of your avant??
leaner mixture will increase the exhaust temps true??RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
thats mixed, which means movement in the city/short distances as well as motorway cruising. When moving short distances and on lower gears, you get more fuel consuption,and one of the reasons is the continuous accel enrichment engagement. Cruising only on motorways, should give me less than that.
leaner will give more EGTs but im still well within limits.
replacement WI pump should be here tomorrow,so installation in the weekend is likely.
Unfortunatelly i feel like looking towards the bomb replacement afterall, since the pedal still feels vague and spongy. Also the pedal goes hard after 5-6 presses on off engine... I hope the new bomb will work. need to send this one to Paul for a check...
As mixture is becoming a tad richer than i want, i have retuned the WI not to reach max water/meth spray on 2bar, so that everything stays within limits and the IATs just stay stable on the runs.
I have acquired some APR R1s as well in exhange for my forge units. Nothing wrong with the forge 006, but i wanted to try the APR ones as well to see the differences. Will post some photos once i receive them.
on cruise you wont see too bad an increase in egt. its timing based really there. the limits are not defined. poor running/damage are the limiting factors. hotter also means velocity and velocity helps performance.
what happens is the smoothness goes a little and it may sound on the edge of misfire. i see around 30mpg on the motorway. did you check tyre pressures on the runs to ensure its the same.
id swap those forge/baileys for real valves. gotta be leaking boost at those pressures.
egts are still ok and i have decreased the timing as well.i had 3 more people in the car,and the rs2 is heavier as well.i have played a lot with mixtures now amd i think im at the limit of the car feeling normal at all times.within the city i get around 13l/100, so i am basically around stock levels.
apr r1 are supposed to be very good.ill see if there is a difference
Vas, this was a very good thread to read, for me it reads like the closing chapter of a book without reading the other 10 earlier chapters. I'm at a crossroads whether to start one of these high power projects; its good to see that you are satisfied with the results. Does vems require any special training or did you learn it yourself by carefully adjusting a base map?
, I bet your car creates some surprises for other drivers on the motorway!!Shane
