UrS4 2.2T Avant project
I think they are officially available only outside europe. Don't know why though? Maybe because we here usually don't belive in these kind of "racing" nonsense.
BMW 740iA e38 - ProjectComment
Is the T137R the same as the T137RB? (CA18DET?)
H tune do T137R for £40 in the uk, 3-4 week special order though.
T137RB seems to be readily avaliable in the US.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
any update thomas?audi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injectionComment
Nothing happend here. I have been waiting to move to another garage. The new garage build have been delayed now for 3 months, but finally it seems that we can move this month. I did take the UrS out for a drive though. Now in March it's leagal to drive with summer tyres here.
But have to say, the grip on snow with these cheap summer tyres is amazing, not any worse than with those mid european winter tyres. But anyway, the price of the fuel gives you a smile on the face.
Here you go.
Victor Reinz part numbers Audi 2.2T (AAN, ABY, 3B, ADU)
Name / Reinz part number / OE part number
Crank Case Gasket set 08-29178-01 / OE 034 198 011B
Cylinder Head Gasket set 02-29335-01 / OE 034 198 012M (incl. valve stem seals)
Cylinder Head Gasket 61-29335-00 / OE 034 103 383AD
Valve Stem Seal kit 12-26058-04 / OE 027 109 675 (20 pcs)
Valve Stem Seal 70-26058-00 (1 pcs)
Intake Manifold Gasket 70-27626-00 / OE 034 129 717K
Exhaust Manifold Gasket 70-27088-10 / OE 034 129 589A
Oil Pan Gasket 70-29178-10 / OE 074 103 609F
Valve Cover Gasket 15-27624-01 / OE 034 198 025F
Crank Shaft Seal front 81-24292-10 / OE 069 115 147C
Crank Shaft Seal rear 81-23708-40 / OE 068 103 051P
Cam Shaft Seal 81-19299-10 / OE 056 103 085B
Head Bolt kit 14-32049-01 / OE 034 103 385C (12 kpl)
How about those Ross Racing forged pistons, you got. What should be the static comp ratio? What was the comp height and dome capacity?
I also have good experience of Ross racing piston, in my "Batmobile" UrS4. And because also building stroker for that S2 of mine.... so, I'm interested about your piston setup also.
Even though i might build it with 159mm rods.....
I don't remember exact figures anymore, but the piston dome is guite big and deep. The compression was some way under 8 if I remember right, but I may shim the block a little bit to get tighter squish. This will not be a high efficiency engine. In stead will be made to take 1000+hp if nessesary. These pistons have been on the shelf for like 10 years, I was buying them from AnLe few years back, but propably you can order any spec pistons from Ross these days also.
Thuppu fantastic job done here!!! Your project is like a book, for those who just starting build own cars)))) much respect for posting and writhing all that stuff down from the first page!!Audi S6 C4 2.2T Quattro 1997, full rebuild....
Audi A5 Sportback V6 2.7 TDI 2011
Volkswagen Phaeton V6 3.0 TDI 2009Comment
0-200km/h 9sec
