UrS4 2.2T Avant project
  • AndyP
    • 6049
    Originally posted by diesel des
    Yea I see one listed from Australia on eBay. Seems a long way to come for a belt.
    I just found the same one, only £55 delivered. I can't find one in UK or Europe
    • diesel des
      • 3896
      #1742
      Ordered. 3 left...
      • Thuppu
        • 4115
        I think they are officially available only outside europe. Don't know why though? Maybe because we here usually don't belive in these kind of "racing" nonsense.
        • andy10v
          • 5996
          Is the T137R the same as the T137RB? (CA18DET?)
          H tune do T137R for £40 in the uk, 3-4 week special order though.
          T137RB seems to be readily avaliable in the US.
          Sold ABY-stock
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            #1745
            any update thomas?
            TWINCHARGED power,zero lag
            AEM W/M injection
            • Thuppu
              • 4115
              Nothing happend here. I have been waiting to move to another garage. The new garage build have been delayed now for 3 months, but finally it seems that we can move this month. I did take the UrS out for a drive though. Now in March it's leagal to drive with summer tyres here. But have to say, the grip on snow with these cheap summer tyres is amazing, not any worse than with those mid european winter tyres. But anyway, the price of the fuel gives you a smile on the face.
              • Takumi
                • Oct 2009
                • 120
                • Home: Lithuania Current: United States
                #1747
                Originally posted by Thuppu
                Hey, would you kindly share Victor REinz PN# for whote gasket set? If i'm not mistaken - there is one with oil pump, seals, gaskets in one?
                BLOG: http://quattro10vt.wordpress.com/
                • Thuppu
                  • 4115
                  Here you go.
                  Victor Reinz part numbers Audi 2.2T (AAN, ABY, 3B, ADU)
                  Name / Reinz part number / OE part number
                  Crank Case Gasket set 08-29178-01 / OE 034 198 011B
                  Cylinder Head Gasket set 02-29335-01 / OE 034 198 012M (incl. valve stem seals)
                  Cylinder Head Gasket 61-29335-00 / OE 034 103 383AD
                  Valve Stem Seal kit 12-26058-04 / OE 027 109 675 (20 pcs)
                  Valve Stem Seal 70-26058-00 (1 pcs)
                  Intake Manifold Gasket 70-27626-00 / OE 034 129 717K
                  Exhaust Manifold Gasket 70-27088-10 / OE 034 129 589A
                  Oil Pan Gasket 70-29178-10 / OE 074 103 609F
                  Valve Cover Gasket 15-27624-01 / OE 034 198 025F
                  Crank Shaft Seal front 81-24292-10 / OE 069 115 147C
                  Crank Shaft Seal rear 81-23708-40 / OE 068 103 051P
                  Cam Shaft Seal 81-19299-10 / OE 056 103 085B
                  Head Bolt kit 14-32049-01 / OE 034 103 385C (12 kpl)
                  • Takumi
                    • Oct 2009
                    • 120
                    #1749
                    Thanks!
                    • VilkkuS
                      • Aug 2014
                      • 20
                      How about those Ross Racing forged pistons, you got. What should be the static comp ratio? What was the comp height and dome capacity?
                      I also have good experience of Ross racing piston, in my "Batmobile" UrS4. And because also building stroker for that S2 of mine.... so, I'm interested about your piston setup also. Even though i might build it with 159mm rods.....
                      • Thuppu
                        • 4115
                        I don't remember exact figures anymore, but the piston dome is guite big and deep. The compression was some way under 8 if I remember right, but I may shim the block a little bit to get tighter squish. This will not be a high efficiency engine. In stead will be made to take 1000+hp if nessesary. These pistons have been on the shelf for like 10 years, I was buying them from AnLe few years back, but propably you can order any spec pistons from Ross these days also.
                        • Spyform
                          • Mar 2016
                          • 288
                          Thuppu fantastic job done here!!! Your project is like a book, for those who just starting build own cars)))) much respect for posting and writhing all that stuff down from the first page!!
                          Audi S6 C4 2.2T Quattro 1997, full rebuild....
                          Audi A5 Sportback V6 2.7 TDI 2011
                          Volkswagen Phaeton V6 3.0 TDI 2009
                          • Thuppu
                            • 4115
                            Room for the IC... 550x600x50mm two row core for the rear radiator.
                            • diesel des
                              • 3896
                              #1754
                              Your in for a lot of work I think. Cool.
                              • V6quattro
                                • Sep 2008
                                • 949
                                Yep this is out of control now
