80q b4 2.2 20vt project
  • Thuppu
    • 4115
    Started to improve the breather system, as my previous simpple system isn't good enough. Need a different outlet on the valve cover, the rear isn't good. There will also be a return to the sump...
    Modded a 7A valve cover to a PKK Motorsport version.
    EDIT!!!! impossible to post pics with mobile!!!!!!!!!!!!!!!!!!!!!!!!!!!
    • afterthought
      • May 2014
      • 128
      Man that valve cover came out so cool. I tried doing similar once by grinding the ribs off then powdercoat but it doesn't come out near as perfect
      • Thuppu
        • 4115
        Oil fill will be though the breather catch can return.
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          #229
          realy nice thomas
          TWINCHARGED power,zero lag
          AEM W/M injection
          • Thuppu
            • 4115
            Thanks Nick!
            Color is KTM orrange. Brake calipers will be the same.
            • Tom_
              • Oct 2007
              • 1301
              • Country: Czech Republic
              #231
              Looks good Thuppu, but why blinded the oil cap? That breather outlet its just and hose end or something more difficult system which is inside cover?
              Audi Coupe Quattro 2.3 20V
              • Thuppu
                • 4115
                Just wanted clear look and something different. No problem to fill up without it. The breather outlet is just a dummy hole without anything fancy.
                A couple of showoff shots before the color burns away from the exhaust wrap.
                • quattro-nick
                  • Sep 2012
                  • 1746
                  • Country: Belgium
                  #233
                  Did you use the same paint as the valve cover thomas? That will be fun at the first test drive
                  AEM W/M injection
                  • Thuppu
                    • 4115
                    No, I didn't paint it, it was orrange colored from ebay. Smells quite bad though.
                    • Thuppu
                      • 4115
                      Got the Vems launch control working today. I'm not very good with electrics, but EFI express had a nice tutorial of how to do it, so can't go wrong there: http://www.efiexpress.com/catalog/ar...articles_id=12
                      It's now activated by the clutch pedal and it has an external on/off switch. Strange though I had to use channel 5 for my setup, not channel 7 as usual on AAN Vems. But anyway it now works.
                      Small test vid https://youtu.be/FTICv_wilak
                      • Henkjan
                        • 1705
                        Originally posted by Thuppu
                        I will keep this simpple and as an everyday user ....
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          #237
                          very nice,did the same thing with my car,little vid from launchcontrol outside
                          AEM W/M injection
                          • Thuppu
                            • 4115
                            Nice vid Nick! Must take something similar when I remove the cat, don't want to melt it.
                            Henkjan, whaaat haha? I have been using this daily ​​​​​​
                            • AndyP
                              • 6049
                              Do you find that having the vacuum resevoir gives you any extra braking power or does it just give you some back-up if the engine fails?
                              • quattro-nick
                                • Sep 2012
                                • 1746
                                • Country: Belgium
                                #240
                                it cant give you extra power,only more back-up by engine fail
                                AEM W/M injection
