Large IC install/pluming
This is a sticky topic.
Silicon Tubes for Intercooler - Short Intake Manifold and Water Hose for Main Watercooler and 2nd WatercoolerAttached FilesComment
Problem is, it is a very expensive solution unlike the original fit on this thread by Bo and mine over in Audifans (S6).
Yours is very nice and looks easy to fit, and is as neat as hell but a very understanding bank manager is needed
Jim B
97 S6 AAN Quattro Avant C4 | Powerflow Cat Back EX | Milltek Hyperboost RV | MAC N75 Valve | FMIC | HID's (Dip & Fog's)| MRC Re-map SII | Carbon interior | De-chromed | Short shift | Samco Air Hoses |
http://smogthemog.blogspot.com/Comment
There is also This chap to consider also. http://stores.ebay.co.uk/Universal-I...enameZL2QQtZkm
I bought my intercooler off of him and he was VERY helpful indeed.
I used the 'large' sized one he does.
See My thread here: http://www.audifans.net/modules.php?...wtopic&t=15234Last edited by smogthemog; 22 October 2007, 04:29.Jim B
Crossmember on the way, thanks Bo! 600x300x76 IC ordered and a DIY pipe kit in 76mm too, seems like I've taken the plunge! Hope its all the right size!
Bo, your IC was 76mm in and out yes? There's something in the thread that contradicts this..Comment
Hi Azman.
In your sig you mention you have 'chopped' your manifold?
What exactly did you do to it mate as I would be interested to know in respect to doing it to mine?
JimJim B
IIRC bo yours was the 63mm inlet and outlet, i've seen the 76mm one's on the bay and will have to go for that as from what i've heard the guy cannot get the 63mm one's anymore, just have to use some spacers or a pair of mark h mods to take up the difference.Comment
@ smog - Right then, slice off round the back plate of the IM (the part that the TB mounts to) using a very thing grinding disc, cut a square out and work from there taking off as little as possible.. there is a thread on here somewhere I will have a look for, I used it a s a guide and then got it all welded with some crossbars to prevent the rplacement plate from buckling under boost and cracking the welds again!!!!Dark Grey Avant
RS2 FARB
Alloy Subframe BushesComment
Dark Grey Avant
RS2 FARB
