Project 450 - Will it be enough!
  • Jonas_R
    • 3780
    • Country: Denmark
    #211
    You I got the gift thanks
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
    • Jonas_R
      • 3780
      • Country: Denmark
      #212
      Update
      So had to remove the old coil and some brackets to make room for the new coils:
      The wires that were seated in the brackets where moved down behind the catch tank:
      The new flex pipe after, old one did not fit with the combo of Evo RS EM, 034 downpipe and RS2 turbo:
      So started this morning and got the flex pipe on:
      Got the shield for the small vacuum pipe on (never had it before) also got the heat shield on by the turbo. Not that much room, but it clears the oils hoses:
      Half of the airbox is back in place, then MAF-Turbo hose and finally the last part of the airbox:
      • Jonas_R
        • 3780
        • Country: Denmark
        #213
        Update part 2
        Next step was to install the new 034motorsport ignition leads, but hey they are to ****ing big:
        So had to open all the ignition plugs and reuse the metal connector and add the new style plug to my old ignition leads:
        And the end result is 3B ignitions leads with 034motorsport connectors that fits under the plastic cover:
        Getting ready to mount the strut brace with the coils attached, just had to do some last minute adjustments:
        Here we go, coils are installed:
        Doing some measuring to see if we have ground on the strut brace:
        The TTL high and low on the coils from 034motorsport needs to be grounded and the wiring harness has ring terminals for this so I decided to ground them on the strut brace:
        • Jonas_R
          • 3780
          • Country: Denmark
          #214
          The finished result, should take some better pictures
          Now I only need to solder the five trigger signals and then it should be ready to start.
          I think this if others wants to do this conversion then you need the following:
          5x high output coils
          5x metal connectors for your 3B ignition leads
          5x connectors for 034motorsport coils
          1x mounting brackets - these include spacer and rods to mount the coils or some sort of brackets.
          • Acidburn
            • 13459
            Looking good and love the attention to detail you've gone thru, just wondering what airbox you running? rs2? and have you had to modify it at all?
            • Jonas_R
              • 3780
              • Country: Denmark
              #216
              yup running RS2 airbox, no mods needed to fit it. However some sort of air duct would properly help
              • david
                • Oct 2008
                • 1268
                Well done jonas,maybe you can give me a few tips.Since i want to do same project as you
                [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
                RS2 VOLCANO BLACK] soon to be broken to bits
                • Jonas_R
                  • 3780
                  • Country: Denmark
                  #218
                  Sure David, just ask and I will do my best to answer
                  • urquattro-island
                    • Mar 2006
                    • 1915
                    • Home: Norway Current: Iceland
                    #219
                    that
                    brown sensor on the inlet pipe what is that, arnt you using motronic?? i dont have this??
                    japanischer industriabfall nein danke!!
                    www.rackeltrim.se Icelandic Division
                    • quattrostyle
                      • Oct 2006
                      • 6229
                      inlet temp. sensor?
                      • Jonas_R
                        • 3780
                        • Country: Denmark
                        #221
                        Here is some more info:
                        However it is supposed to be used with this welleman K8067 and then used on my Zeitronix to log inlet temperatur
                        • urquattro-island
                          • Mar 2006
                          • 1915
                          #222
                          aha
                          was just curious why two intake temp senders. thanks..
                          • Jonas_R
                            • 3780
                            • Country: Denmark
                            #223
                            Update - ECU
                            ECU is now installed and car is ready to run
                            So hoping that it will work when I crank it in a few minutes
                            • Jonas_R
                              • 3780
                              • Country: Denmark
                              #224
                              Here is what happen when I tried to crank it the first time:
                              Movie.....
                              • CliveH
                                • Jun 2005
                                • 1319
                                #225
                                sweet Jonas!
                                Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
                                Present: S4 B8 avant, MRC Stage 2
