UrS4 2.2T Avant project
    The term "over-engineered" comes to mind for this set-up
    • Acidburn
      • 13459
      a guy down southampton way had 321bhp on a 3b running a tubular manifold, super unleaded and the same mapping technique as automark uses. The turbo was proper screwed when it was removed but went well for what it was.
      • cartune
        • Jan 2008
        • 13
        • Country: Russian Federation
        #693
        Winter tuning)) good idea
        • europeanme
          • Oct 2005
          • 3817
          Originally posted by Thuppu
          oh no Thomas, thats such a sad picture..... after that shiny new turbo...but I suppose needs must...gotta keep the MOT man happy....
          • Bram
            • Aug 2006
            • 2582
            Good for you the rest of the engine bay does not look suspicious
            • Thuppu
              • 4115
              MOT test = pass!
              • prj
                • Mar 2010
                • 6308
                How does the car start? I did not almost tune the cold start at all, just put some "guessed" values.
                I guess it will not start if it is outside, right?
                • cartune
                  • Jan 2008
                  • 13
                  #698
                  Hello from Russia
                  • quattro84
                    • Mar 2006
                    • 947
                    Originally posted by cartune
                    Hello from Russia
                    Using a watercooled CHRA i see? Where did you get that?
                    @Thuppu: Do yo need to swap over the turbo's every year to pass the MOT??
                    • cartune
                      • Jan 2008
                      • 13
                      #700
                      Yes, it from kkd too
                      • Thuppu
                        • 4115
                        It has been only indoors so I don't know yet, tomorrow we see, after cooling down over the night. Minus 10 degrees here now.
                        Hello from Russia
                        Nice turbo, mate.
                        Hope not. It depends on how tight the MOT guy is. This guy who checked the car now wouuld propbly have let the car pass last time. Really nice guy, not too tightass.
                        • Thuppu
                          • 4115
                          You'r right. It won't fire up. It's totally dead.
                          • prj
                            • Mar 2010
                            • 6308
                            This is expected. The timing has to be modified and also the enrichment...
                            It's not so easy to get the cold start right with E85...
                            Well, get it indoors for now.
                            What do you have in the car? Still the summer blend of E85? If it is the summer blend I am not sure it is at all possible to start the car in -10C.
                            With winter blend and lots of tuning it should start.
                            Can you buy a DEFA electric warming system for the engine block, so you can plug it in?
                            This should not be very expensive...
                            Alternatively, I can send you a chip, that you can change in the ECU and you can use gasoline for now? I can add a button to switch maps too in the future if you need.
                            Let me know... I don't want you to miss all the fun in the winter
                            Maybe I should take a weekend trip to Finland, I really want to see this car run!
                            • Thuppu
                              • 4115
                              I have the DEFA block heater. I had it plugged for a hour and a half and the car fired up nicely, no problem. -8 degrees outside. Summer blend E85, tank almost full. Could fill few liters of gas, maybe it helps also..?
                              • prj
                                • Mar 2010
                                • 6308
                                You could, but I think it could start with -8C with some more warmup-enrichment.
