Buying an S2 Coupe - Am I walking into a world of pain.
    Originally posted by B5NUT
    Took the car over to automark this morning, looks like the only modification was the ECU, wastegate & N75. So happy days to restore the car back to factory spec. Only other issue was noticed was the smaller diff seal and the seal around the bellows was leaking. So now I can finally start to rip this car apart.
    Did you plug the stock chipset in yet?
    • B5NUT
      • Sep 2021
      • 1071
      Not yet, I wanted to make sure there were no further modifications hiding, before reverting to the standard MAP. Thankfully the answer is no so will get the chips installed this week.
      • B5NUT
        • Sep 2021
        • 1071
        I have a question... So I'm not liking the look of the front subframe. It's got a lot of flaking surface rust and is really in need of being refurbished .From what I can see and have read the front subframe only supports the gearbox, lower arms and roll bar. is it just the case of supporting the gearbox and then dropping the subframe down. Or am I mossing something?
          • Dec 2017
          • 5992
          Yes, just support gearbox and drop.
          • Bowie69
            • Nov 2013
            • 2675
            Yep, disconnect wishbones at ballpoints, and remove the anti roll bar drop links, down it comes.
            No need to support the gearbox if the snub mount is in place, it'll hold it.
            • B5NUT
              • Sep 2021
              • 1071
              Thank what's the best way of stripping the rust. There are companies local to me that shot blast, but I'm not sure if if dipping it would be better, problem with that is I cannot find anyone local in the northeast that provide a dipping service. Other option would be Electrolysis, If I could find a container big enough.
              • Bowie69
                • Nov 2013
                • 2675
                Blasting works well enough, these mostly rot from outside in my experience.
                When all finished fill with some nice aerosol bilt hamber wax
                  • Dec 2017
                  • 5992
                  Agree. Blasting is best then powder coat if it's going to be a garage queen, por15 or epox for a daily. As Bowie says, bilt stuff is very good.
                  • B5NUT
                    • Sep 2021
                    • 1071
                    Don't rate por15 anymore. Used to be really good, couple of years back I fixed up an A3 and did the hole rear subframe with the stuff, 6 month months later the rust was back with avengeance. For me it's either power coating. epoxy or both... Think the subframe will be power coated then an extra few layers or epoxy for protection.
                    Also you lot could have warned be about the strut cap'sMy god were they on, think I need a better set of stilsons. Had only got that bar to remove the crank bolt, didn't think I'd need it for the suspension.
                    Still suspension stripped and subframe is out.
                    Off to the shot blasters tomorrow with the subframe and the other suspension parts covered in rust. .
                    • Bowie69
                      • Nov 2013
                      • 2675
                      Yeah, strut caps often need cutting off, but heat works well too if replacing the shock ?
                      • B5NUT
                        • Sep 2021
                        • 1071
                        O yes, both shock were absolutely cattle trucked, and in need of replacing. The near side suspension was covered in oil which has been poring out the shock. Other than the cap the strip down was not that bad, only issue I have run into is pressing out the wheel bearings, my 10 ton press is not in the best of conditions and struggles to keep pressure. Got it up to 8 ton and still did not move the bearing so will take then to a friends garage tomorrow, and get them both pressed out.
                        • Bowie69
                          • Nov 2013
                          • 2675
                          Some wheel bearings have circlips -do check....
                          • B5NUT
                            • Sep 2021
                            • 1071
                            No circlips, I remove all of the rust around the edge of the wheel bearing housing, so the bearing would not have to pass a thick rim of rust, but even with that and a mapp torch for heat and 8ton of pressure it still did not budge..
                            • Bowie69
                              • Nov 2013
                              • 2675
                              Time for a BFH.....
                              I have a 20t press for this sort of thing, not beaten it yet, but sure there will be something at some point.
                              • B5NUT
                                • Sep 2021
                                • 1071
                                Yes, I need a new one along with a 450nm torque wrench, big **** stilsons + any other tool this car needs.
