Bl0Ody hell, if you think that's 'miles out' you should see a 'genuine' Audi Ur Quattro replacement front wing panel, it's 60 man hours worse than that....
That's superb, and superb work...
93 MTMS2 Avant
Rear wings have arrived! A big thanks to Tonks for them! They look a good quality mould. Going to require a lot of metal to be cut off the car to get them to fit, shouldn't take too long once the grinder is fired up!
A few more pics of whats been going on and what has arrived!
Folded a piece up to cover the remaining bit of the old firewall as it was slightly unsightly:
Then I cut the sills and rear arches off.
The fuel swirl pot turned up last week from Pro Alloy. Hand made one off and is a real work of art! Also managed to get the last set of sport quattro headlights from Quattro corner!
I have also started scraping the underseal off. What a great job that is, not!
I managed to get the rear wings to sit somewhere near, so put 3 big self tappers in to hold them:
Some inner rear arches bent:
Then a pair of new sills bent up:
Then they got some axle stand mounts welded into them, with some strengthening spars. There are also 2 metal pads to go underneath each sill as jacking points, although with the cage it will probably jack up on just the front one.
The front pipe is going to end up being linked into the cage mount:
They arn't so far off being finished, just the jacking points to weld on. They will go underneath the strengtheners for the axle stand mounts so it should be nice and solid!
i just love reading and watching what you've done, great work will look so sweet when finished. when do you think you might have it finished? and how many site you posting on lol.
I think it will be finished in 2010. Next year will be spent building the car and a suitable special engine. Its being posted on a few. Mostly VW sites as thats where my heart is!
