Lovely now take the car for a drive!!
Audi 80 Avant
quick drive...
sound has been reduced, now only starts to whistle above 100kpa( 0 bar) and only on boost it will give a whistling sound, which is acceptable by my standards. So the ring works. Different kinds of filters will play a role, but for me its done.
1.5bar 3d gear @ 4000rpm. Not bad at all.. I suppose if i ask from vems 2bar at point, it might bring the overall curve faster,but that remains to be seen... EGT @ 0.80 5800rpm 815 (sensor is on the EM collector).. i think it looks good there.Last edited by A80Avant; 8 May 2010, 15:54.Comment
removed it now. I kept the hole cause i read somewhere that later versions of vems, could operate both sensors, so could have better lamda control in mid range for economy
by the way im at about 1.09 lamda from 2000-3000 on vaccum and its ok!
the filter is definitelly restrictive but i have no space to fit something bigger at an angle, unless i cut the inner fenderComment
i can fit a 90deg elbow if needed,but i need to cut the area to pass it below, and then see where to take it. I still have all the A/C equip there so its difficult to pass it through.Also my oil cooler sits at that space below the right side of the bumper which means that if im lucky it might pass through behind it.Hot air though then...Comment
