Audi 80 Avant
  • A80Avant
    • 10873
    • Country: Greece
    #301
    i had to make a few more changes to the fuel enrichment table, and it seems that mine in the end tends to need less than 106 on small throttle angles and about 106 on higher throttle angles. Also i readjusted the fuel cut settings and it eliminated the idle dip when the car goes to neutral.
    i have to find some time to do some more idle testing though so as to make it even better.
    here is a more recent photo...needs a wash unfortunatelly!
      are you running the 245/35s in that pic Vas?
      • A80Avant
        • 10873
        • Country: Greece
        #303
        yes i do, with 3mm spacers front and 5mm rear
        • Billman
          • 4129
          #304
          Do you need spacers for this combo?
          Go Holset or Go RS4
          • A80Avant
            • 10873
            • Country: Greece
            #305
            Yes apparently the wheels come very close to the suspension parts
            • Billman
              • 4129
              #306
              what do the other use with 18 wheels on the RS2?
              Go Holset or Go RS4
              • A80Avant
                • 10873
                • Country: Greece
                #307
                i know that Rob (GT500) has 3mm spacers in front, but nothing at the back, but his 18inch are 8.5 width and different ET i think
                • A80Avant
                  • 10873
                  • Country: Greece
                  #308
                  2 days ago, i found a small hose from the back of the IM that goes to the PCV system torn. I rerouted some of the vaccum hoses and checked for leaks of the system and i think that the problem i get with the idle not being able to go below 940rpm is the fact that the 70mm TPS is not sealing properly as it should.
                  I may need to make a new one with Aelred which has better seal to be able to have a wider margin of correction with the idle valve. ATM i need to have the valve completelly shut on warm engine to keep the idle at 900ish rpm and the rest is done by ignition timing adjustment.
                  Not bad, and actually could stay as it is, but im a control freak...
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #309
                    today i did a bit more fiddling so i managed to get the idle speed stable with the DC above 30 (not 40 unfortunately) but that's ok as it is nicely controlled now.
                    i also did some runs today to see the differences in the timing and the WI use.
                    here are 2 nice logs, on the 4th gear pull. Notice the reduced IAT on the WI which is always welcomed!
                    (on the second image, as EGO freeze was on, the lamda is very low, but that is fixed on the + WI run.So pay no attention to the EGTs as they are not comparable.)
                    After fixing the leak my boost is coming a bit faster again! yeah!
                    Now its on 4th gear around 3850-3900 when i get 2bar and on 3d gear i have it on 4100ish (previously about 100-200rpm later) amazing what a boost leak can do. From no symptoms to very significant symptoms!
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #310
                      Wheel alignment done and a bit of cleaning yesterday.
                      funnily enough after the wash, the idle was kept on 1800rpm and the TPS was at 1.6% why?
                      so i took out the ISV to see if it was sticking on one hand, then tried to see if there was anything wrong with the TB. Readjusted everything, and it droped to 0.8%
                      Recalibrated the TPS, and everything went back to normal, with the pleasant welcome of the idle going to 940-950 with the DC of the ISV now being at 33!!! I had to readjust the PID a bit, but now its much nicer!
                      • pixsaudisex2
                        • Sep 2004
                        • 3110
                        #311
                        Looking good ...
                          I really don't understand a word you said Vas but the RS is looking sweet
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #313
                            haha!
                            i didnt write it in Greek, did i?
                            • A80Avant
                              • 10873
                              • Country: Greece
                              #314
                              small bling update.
                              lavamat cover to ... cover the alloy heat/sound absorbers.
                              although night time and crappy phone photo, i think it looks much better!
                              • A80Avant
                                • 10873
                                • Country: Greece
                                #315
                                better picture!
