Titanium Grey S4 Avant
With multimeter.
Have 12v at terminal 15, and on both sides on the fuse, but no voltage at pin 27 or injector plugs. Looking at the wiring diagram for ECU, it goes straight to the pin 27 after the fuse. I have looked at the wiring and I can't see any breaks etc?
It's too late for that. But thanks.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
I was looking at getting these, any good?http://m.ebay.co.uk/itm/390752501981'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
You might get them out by hammering the next size up torx bit in there, that's the best way. Those spiral bolt extractors don't often work very well.. Welding a nut onto the head of the bolt is good too. If all else fails, grind the heads off then you can weld a nut to what's left and get them out that way, or maybe mole grips.Comment
Did you miss my post (No.60) with these?I was looking at getting these, any good?http://m.ebay.co.uk/itm/390752501981
How would I go about rewiring it from fuse to injectors and pin 27, as it seems the best way to me?Have 12v at terminal 15, and on both sides on the fuse, but no voltage at pin 27 or injector plugs. Looking at the wiring diagram for ECU, it goes straight to the pin 27 after the fuse. I have looked at the wiring and I can't see any breaks etc?'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
Maybe go back to trying to get the empty tube out?Comment
There's another type of extractor, for nuts and studs, that fits over the outside of the bolt head, try Irwin stud extractor.Comment
